Hi All,
I have thousands of buildings which few contains donuts, according to the customer requirement would like to remove donuts.
Hence, Kindly provide a solution how can i remove these donuts using .net program.
Thanks in Advance
Here is a Python function that does what you need:
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">fill_donut</SPAN><SPAN class="punctuation token">(</SPAN>in_lyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'''Edits a layer in-place and fills all donut holes or gaps in the selected features. Will operate on entire layer if there are no features selected. Requires layer to honor selected features. '''</SPAN> desc <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>in_lyr<SPAN class="punctuation token">)</SPAN> shapefield <SPAN class="operator token">=</SPAN> desc<SPAN class="punctuation token">.</SPAN>ShapeFieldName rows <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>in_lyr<SPAN class="punctuation token">)</SPAN> n <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN> polyGeo <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Array<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># to hold edited shape</SPAN> polyOuter <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Array<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># to hold outer ring</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> rows<SPAN class="punctuation token">:</SPAN> feat <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">.</SPAN>getValue<SPAN class="punctuation token">(</SPAN>shapefield<SPAN class="punctuation token">)</SPAN> qInterior <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN> <SPAN class="keyword token">for</SPAN> partNum <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN>feat<SPAN class="punctuation token">.</SPAN>partCount<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> part <SPAN class="operator token">=</SPAN> feat<SPAN class="punctuation token">.</SPAN>getPart<SPAN class="punctuation token">(</SPAN>partNum<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> pt <SPAN class="keyword token">in</SPAN> iter<SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">lambda</SPAN><SPAN class="punctuation token">:</SPAN>part<SPAN class="punctuation token">.</SPAN>next<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>None<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># iter stops on null pt</SPAN> polyOuter<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>pt<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> part<SPAN class="punctuation token">.</SPAN>count <SPAN class="operator token">></SPAN> len<SPAN class="punctuation token">(</SPAN>polyOuter<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> qInterior <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN> polyGeo<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>polyOuter<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># reassemble each part</SPAN> polyOuter<SPAN class="punctuation token">.</SPAN>removeAll<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ready for next part</SPAN> <SPAN class="keyword token">if</SPAN> qInterior <SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># in any part of this feature, otherwise skip update</SPAN> n<SPAN class="operator token">+=</SPAN><SPAN class="number token">1</SPAN> row<SPAN class="punctuation token">.</SPAN>setValue<SPAN class="punctuation token">(</SPAN>shapefield<SPAN class="punctuation token">,</SPAN>polyGeo<SPAN class="punctuation token">)</SPAN> rows<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN> polyGeo<SPAN class="punctuation token">.</SPAN>removeAll<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">del</SPAN> rows<SPAN class="punctuation token">,</SPAN>row msg <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Features with interior ring filled "</SPAN><SPAN class="operator token">+</SPAN>str<SPAN class="punctuation token">(</SPAN>n<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN>msg<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>RefreshActiveView<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I think Joshua Bixby has the right idea. Take a look at "IPolygon4.ExteriorRingBag" which creates and returns a geometrybag that contains references to all exterior rings. You can take this and create a polygon with it and the donuts won't exist.
Yep, IPolygon.FindExteriorRings is the method.
If you want to use geoprocessing or python you can also use the Eliminate Polygon Part tool.
A haven't done .NET programming in years, well, years and years. Although I can't offer you specific objects and functions, I can say that polygons are made up of a series of linear rings. If you can find and extract the exterior ring, you can create a polygon using it, and the donuts won't exist. Or, you could try to remove the interior linear rings. I am not sure which would be easier.
