Hi all,
I am trying to add some data to overview map (county outline). Is it possible?
Alex
Alex,
I think Sayak Nag is not reading that part were:
but I want to add a layer to the "Overview Map" not the map itself
This is not possible using the Add Data Widget.
I have been working on some customization to the overview map widget to try and add a layer but as of yet have been unsuccessful.
You can use the Add Data widget in Web AppBuilder. Click this link for more information on the widget.
Thank you Sayak but I want to add a layer to the "Overview Map" not the map itself. Is it possible?
Yes, the Add Data widget let's you add a single layer as well. To add layers by URL, click the URL tab next to the Search tab. Choose a type and enter the URL. Click Add to add the data to the map. The added layer will appear in the Layer List widget as well. The following types are supported through the URL:
It's also mentioned in the link I shared, under the "Using the Add Data widget" section.
