/* * Apply a renderer for vector layers. * Note: It is always necessary to provide a renderer when the layer being added (represented by a DynamicLayerInfo) is part of a new * DynamicLayerInfoCollection as opposed to using the CreateDynamicLayerInfosFromLayerInfos() method which creates a DynamicLayerInfoCollection * containing the existing layers in the map service. */ // Create a new LayerDrawingOptions object to hold the renderer information. var layerDrawOpt = new LayerDrawingOptions() { // Match up the LayerID to the ID of the layer within the service. LayerID = counter, }; // We need to determine the geometry type of the new feature class. // To do this, we will submit a request to the ..\MapServer\dynamicLayer?.. endpoint which will return the service level metadata, // Allowing us to identify the geometry type and create an appropriate renderer. // Create a new WebClient instance to make the request and download the response. WebClient webClient = new WebClient(); // Register an asynchronous handler in which to create the renderers and apply the to the dynamic map service layer. webClient.DownloadDataCompleted += (client, downloadDataEventArgs) => { // Read the JSON response as XML XmlReader reader = System.Runtime.Serialization.Json.JsonReaderWriterFactory.CreateJsonReader(downloadDataEventArgs.Result, new XmlDictionaryReaderQuotas()); // Get the root XML element XElement root = XElement.Load(reader); // Query for the "geometryType" element XElement geometryType = root.XPathSelectElement("//geometryType"); // Create the render based on the geometry type switch (geometryType.Value) { case "esriGeometryPoint": layerDrawOpt.Renderer = new SimpleRenderer() { Symbol = new SimpleMarkerSymbol() { Color = new SolidColorBrush(GetRandomColor()), Size=8 } }; break; case "esriGeometryPolyline": layerDrawOpt.Renderer = new SimpleRenderer() { Symbol = new SimpleLineSymbol() { Color = new SolidColorBrush(GetRandomColor()) } }; break; case "esriGeometryPolygon": layerDrawOpt.Renderer = new SimpleRenderer() { Symbol = new SimpleFillSymbol() { Fill = new SolidColorBrush(GetRandomColor()), BorderBrush = new SolidColorBrush(GetRandomColor()) } }; break; } // Set the LayerDrawingOptions property on the local dynamic map service layer (the LayerID property ties this to the DynamicLayerInfo object). layerDrawingOptionsCollection.Add(layerDrawOpt); // Update the layer drawing options property on the dynamic map service layer. arcGisLocalDynamicMapServiceLayer.LayerDrawingOptions = layerDrawingOptionsCollection; // Need to refresh the layer after the renderer(s) have been applied. arcGisLocalDynamicMapServiceLayer.Refresh(); }; // Make the request for the service metadata // e.g. http://127.0.0.1:<PORT>/arcgis/rest/services/<MPK_NAME>/MapServer/dynamicLayer?layer={"id":0,"source":{"type":"dataLayer","dataSource":{"type":"table","workspaceId":"MyWorkspace","dataSourceName":"MyFeatureClassName"}}} webClient.DownloadDataAsync(new Uri(arcGisLocalDynamicMapServiceLayer.Url + "/dynamicLayer?layer={'id':" + counter.ToString() + "," + "'source':{'type':'dataLayer','dataSource':{" + "'type':'table'," + "'workspaceId':'"+ workspaceInfo.Id + "'," + "'dataSourceName':'" + fileName + "'" + "}}}"));
Hi,You've actually got several options here... #1. QueryTask:- Probably the best option... set the search geometry via the Query Class (http://resources.arcgis.com/en/help/runtime-wpf/apiref/index.html?ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Query_members.html).#2. GeometryService task:- The GeometryService is typically very quick/efficient but this route would require first retrieving the polygon geometries to submit as graphics which may incur an overhead (you'd need to submit a query first). Take a look at the Relation operation:API ref: http://resources.arcgis.com/en/help/runtime-wpf/apiref/index.html?ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.GeometryService~Relation.htmlSample: http://resources.arcgis.com/en/help/runtime-wpf/samples/index.html#/Relation/02q200000056000000/#3. Geoprocessor task:- This would require creating a model/script and packaging as a GPK but you could craft the GP tool to give you the exact response you want (e.g. just a boolean yes/no).CheersMike
