I downloaded the latest version of the LocalLayer widget (1.2.2-last upated on 11/17/2015). I am attempting to use it with WAB 1.3 and am finding some issues.
Is version 1.2.2 compatible with WAB 1.3?
Eric V
Gurnee, IL
Eric,
I have it working just fine in WAB 1.3 after follow the advice in this thread:
Re: LocalLayerWidget and AccessifizrWidget
I went back and did a fresh "install" of WAB1.3, and made the appropriate changes to the 2 files - but this time I changed the config.js file in the "Default" app under the "predefined-apps" folder. My last attempt I only updated the config.js under the stemapp folder. I then created a new application and the widget showed up properly.
Sounds like you need to go to this url and follow the steps for setting up the widget
GitHub - cmndrbensisko/LocalLayer: The LocalLayer Widget for ArcGIS Web AppBuilder is intended to allow the direct addit…
Because from the looks of it you have something wrong in the setup.
Hi Robert,
I have made the 2 tweaks to the code (config.json & LayerInfos.js).
Creating a new app results in the following view in the Widgets tab - I cannot "edit" the LocalLayer widget.
The LocalLayer widget shows up as "6"....when I click on it, it pops up the widget list....none of which are the LocalLayer widget
