There are a few problems with the code snippet you sent, but the main one from the GeoEvent input point of view is that the message sent is missing a Message Separator indicator. The default settings for the 'Receive text from a TCP Socket' input connector is a '\n' character: 1. Missing Message Separator. 2. Need to use System.Net.Dns.GetHostEntry() instead of System.Net.IPAddress.Parse() to convert a DNS entry into an IP Address. 3. Need to use escaped quote characters to mark two fields as one with the CSV format. This will allow you to pass a "x,y" or a "x,y,z" geometry value correctly as one CSV field. 4. It is recommended to use UTF8 encoding.Following is the corrected code snippet: // ... using System.Net.Sockets; using System.Net; // ... Socket soc = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp); IPHostEntry hostEntry = Dns.GetHostEntry("localhost"); IPAddress ipAdd = hostEntry.AddressList[0]; soc.Connect(ipAdd, 5565); byte[] byData = System.Text.Encoding.UTF8.GetBytes("Vehicle,123,Truck,15,2012-07-24T08:00:00,\"-117.198361,34.055581\"\n"); int bytesSent = soc.Send(byData);-Hanoch
