class ToolValidator: """Class for validating a tool's parameter values and controlling the behavior of the tool's dialog.""" def __init__(self): """Setup arcpy and the list of tool parameters.""" import arcpy self.params = arcpy.GetParameterInfo() def initializeParameters(self): """Refine the properties of a tool's parameters. This method is called when the tool is opened.""" names=set() #Sets only handle unique values rows = arcpy.SearchCursor('Rivers','','','NAME') for row in rows: names.add(row.getValue('NAME')) for param in self.params: if param.name == 'RiverName': param.filter.list=list(names) break return def updateParameters(self): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" return def updateMessages(self): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return
