I'm trying to build an exe using py2exe. My script uses wxPython for a GUI, and arcpy for an Insert Cursor and an Update Cursor on one table inside of a personal gdb. I'm using ArcGIS 10.0 and Python 2.6, and Aptana Studio 3 + pyDev as an IDE.The script works great inside Aptana. My setup.py script executes and creates an EXE file inside of the dist folder of my project directory. When I try to run the EXE, it crashes on import of arcpy. The log file shows the following error:Traceback (most recent call last): File "redrover-hazus.py", line 66, in <module> File "zipextimporter.pyo", line 82, in load_module File "arcpy\__init__.pyo", line 17, in <module> File "zipextimporter.pyo", line 82, in load_module File "arcpy\geoprocessing\__init__.pyo", line 14, in <module> File "zipextimporter.pyo", line 82, in load_module File "arcpy\geoprocessing\_base.pyo", line 14, in <module> File "zipextimporter.pyo", line 98, in load_module ImportError: MemoryLoadLibrary failed loading arcgisscripting.pyd
My setup.py script looks like this:from distutils.core import setup import py2exe, sys, os data_files = ["file1", "file2"] sys.argv.append('py2exe') setup( windows = [{'script': "script.py",'icon_resources':[(1,"icon.ico")]}], zipfile = None, data_files=data_files, options = {'py2exe': { 'includes': "arcgisscripting", 'bundle_files': 1, 'dist_dir': "dist", 'optimize': 2, } }, )All of the users who will run this EXE will already have ArcGIS 10.0 and Python 2.6. Is there a way I can specify this in my setup.py file?-- Josh Groeneveld
