I just noticed that the viewPoint.targetGeometry can only be a Point as it fails silently when it is a polygon or a polyline:
Codepen
Is it a bug or type definition error ?
Nicholas,
That does seems like a bug. Though I am not sure why you would do that vs using goTo with the target of polygonGraphic.geometry and scale of 1000000?
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">goTo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> target<SPAN class="punctuation token">:</SPAN> polygonGraphic<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">,</SPAN> scale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1000000</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hello Robert,
Thanks for the reply.
I am doing that because I have a function that depending on parameters return viewPoint accordingly.
I will use your workaround in the meantime.
Thanks !
