I am using 10.1. How can I easily tell how long a cache runs? In 9.3.1, when the cache completed, the message box would indicate how long it ran.Also, I am using a 16 core machine dedicated to caching only. I set the max instances to 17 but it only ever uses 1. Why??
Ok, I'm up and running at full caching capacity. You need to make sure your CachingTools services is pointed at the correct cluster. I had mine pointed at my wrong one, which only has one machine in it. I pointed it over to my "caching cluster" and now my map service, which is hosted on the first single machine cluster, is caching at full multi-machine cpu capacity. Pretty cool. Really cool actually.-r
What is the "max instances" value for your cachingtools service? If it's 16... and you set your cache to process with 16... and you are only getting one cpu to process... yeah, that is odd.
My max instances in the Caching Tools Service is 17. My min was 0, so I changed that to 1... not sure if that will do anything.. I'm going to try to run again
I'd drop back to 15 or 16... one more than your machine has cores was the 10.0 model. Seems like the new way is "one less". Actually... it's "one less" than the total... so if you are running 4x4core machines (sixteen total) you'd cache with 15 instances. When you have a single 16 core machine.. I'm not sure what you'd set the caching instances to.By the way, you don't have to set the max instances per machine for the map service itself to the number of instances you want to cache at... only the "cachingtools" service needs to be set to that high number.
