Ik heb twee datasets van road polylines en ze komen niet overeen. Welke geoprocessing-functie is er om de "connectedness" tussen de twee datasets te verkrijgen? Dank u.<\/P><\/BODY><\/HTML>
Another possibility is to use the Integrate (Data Management) tool:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Also, as mentioned in the tool help, you may want to consider instead a Topology if one of your layers is more accurate than the other.
Chris Donohue, GISP
Hello Eric,
You could use Reshape feature tool in Editor toolbar. Edit (reshape) the incorrect line to match with the correct feature.
Reshaping a line to match another feature—Help | ArcGIS for Desktop
