private function routeOrders():void{ [LEFT] stops = new FeatureSet([]); var start:Graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(new MapPoint(Model.instance.activeVehicle.attributes.StartX,Model.instance.activeVehicle.attributes.StartY, Model.instance.map.spatialReference)), new TextSymbol('Start',null,0x000000,false,0,true,0xFFFFFF,TextSymbol.PLACEMENT_START,0,20,20)); start.attributes = {Name: "Start"}; stops.features.push(start); foreach(var order:Graphic in Model.instance.oLayer.graphicProvider){ var g1:Graphic = new Graphic(MapPoint(order.geometry)); g1.attributes = {Name: order.attributes.OrderNum}; stops.features.push(g1); } Model.instance.oLayer.add(start); var end:Graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(new MapPoint(Model.instance.activeVehicle.attributes.EndX,Model.instance.activeVehicle.attributes.EndY, Model.instance.map.spatialReference)), new TextSymbol('End',null,0x000000,false,0,true,0xFFFFFF,TextSymbol.PLACEMENT_END,0,-20,20)); end.attributes = {Name: "End"}; Model.instance.oLayer.add(end); stops.features.push(end); if (stops.features.length > 1){ routeTask.solve(routeParams); } }[/LEFT]
[Bindable] private var stops:FeatureSet = new FeatureSet([]); private function routeOrders():void{ stops = new FeatureSet([]); var start:Graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(new MapPoint(Model.instance.activeVehicle.attributes.StartX,Model.instance.activeVehicle.attributes.StartY, Model.instance.map.spatialReference)), new TextSymbol('Start',null,0x000000,false,0,true,0xFFFFFF,'middle',0,20,20)); Model.instance.oLayer.add(start); stops.features.push(start); for each(var order:Graphic in Model.instance.oLayer.graphicProvider){ var g1:Graphic = new Graphic(MapPoint(order.geometry)); stops.features.push(g1); } var end:Graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(new MapPoint(Model.instance.activeVehicle.attributes.EndX,Model.instance.activeVehicle.attributes.EndY, Model.instance.map.spatialReference)), new TextSymbol('End',null,0x000000,false,0,true,0xFFFFFF,'middle',0,20,20)); Model.instance.oLayer.add(end); stops.features.push(end); if (stops.features.length > 1){ routeTask.solve(routeParams); } } <esri:RouteTask id="routeTask" concurrency="last" fault="faultHandler(event)" requestTimeout="30" showBusyCursor="true" solveComplete="solveCompleteHandler(event)" url="http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route"/> <esri:RouteParameters id="routeParams" stops="{stops}" outSpatialReference="{Model.instance.map.spatialReference}" findBestSequence="true" returnStops="true" preserveFirstStop="true" preserveLastStop="true"/>
