Hello, how do I lose what appears to be a subtitle ('1035243.583' in the popup box)? The number itself is from the attribute field called "Easting". I only want to see 'Post Number: 2610010'.
In the web map Easting doesn't appear in the popup:
It looks like you are on Collector Classic, the 'subtitle' field is controlled by the Display Field when you publish the feature service.
Worth noting that this field is not honoured in Collector for ArcGIS at the moment.
Weng,
It is Collector for ArcGIS, actually. Version 18.0.3. I should've mentioned that.
