I'm trying to update to 1.4 (currently on 1.3) but it keeps failing halfway through the process. Something to do with ArcGISPro Help. Here is the log file:
12:37:59: ERROR Upgrade failed on: ArcGIS Pro Help12:37:59: Download operation canceled.12:37:59: MSIInstallProduct failed: error code = 160312:37:00: Attempting to upgrade product: ArcGIS Pro Help12:37:00: Killing satellite process.12:37:00: Killing satellite process.12:36:52: Wating for ArcGISPro process to exit...12:36:52: Found process to terminate.12:36:52: Found process to terminate.12:36:52: Searching for running processes within the update folder.12:36:52: MSI file version: 1.4.719812:36:51: Existing installation detected.12:36:50: Downloaded started...12:36:50: Attempting to open connection to: https://esrisoftware.esri.com/akdlm/software/arcgispro/current/ArcGISProHelp.msi?downloadID=4169848859&type=sms&agolUsername=NA&receiptId=downloads.arcgis.com&__gdb__=1484350610_de4a6c7eef903384b227ba4f9e845e7c&ext=.msi12:36:50: Received REST redirection response.12:36:50: Downloaded started...12:36:49: Attempting to open connection to: https://downloads.arcgis.com/dms/rest/update/secured/ArcGISProHelp.msi?folder=software/arcgispro/current&token=nHE-RZRE1e79HnLdQQdVngeMaX2tSo8UG0Hl4_rVHeBRHQlZc_-rqYX1QnqQHRBQYJ4xlePsicXa4qJzqnE9n5MNWVgHzbfJRqtbOzvyLjT0XYOVUzQRTEN618pFlJvEiPr-uD5At_APjKGzuuNsojinytPAm_2XB8s6PN7LoYi-ljO2Jtf8X1ZpJy4183fLU7sNz8EypOLn2kDNzWePRg..12:36:19: Downloaded started...12:36:18: Attempting to open connection to: https://esrisoftware.esri.com/akdlm/software/arcgispro/current/ArcGISProHelp.cab?downloadID=4169848859&type=sms&agolUsername=NA&receiptId=downloads.arcgis.com&__gdb__=1484350578_bf46b715d8c3736395bd20470bbe831b&ext=.cab12:36:18: Received REST redirection response.12:36:18: Downloaded started...12:36:18: Attempting to open connection to: https://downloads.arcgis.com/dms/rest/update/secured/ArcGISProHelp.cab?folder=software/arcgispro/current&token=nHE-RZRE1e79HnLdQQdVngeMaX2tSo8UG0Hl4_rVHeBRHQlZc_-rqYX1QnqQHRBQYJ4xlePsicXa4qJzqnE9n5MNWVgHzbfJRqtbOzvyLjT0XYOVUzQRTEN618pFlJvEiPr-uD5At_APjKGzuuNsojinytPAm_2XB8s6PN7LoYi-ljO2Jtf8X1ZpJy4183fLU7sNz8EypOLn2kDNzWePRg..12:36:18: Package ArcGIS Pro Help version 1.3.5861 installation detected.12:36:18: Package ArcGIS Pro version 1.4.7198 installation detected.12:36:18: Setting AGOL token12:36:18: Software update initiated.12:36:15: A software update is available.12:36:15: Package ArcGIS Pro Help version 1.3.5861 installation detected.12:36:15: Package ArcGIS Pro version 1.4.7198 installation detected.12:36:15: Setting AGOL token12:36:15: Checking for software update availability.12:36:15: Catalog successfully processed.12:36:15: Downloaded started...12:36:15: Attempting to open connection to: https://esrisoftware.esri.com/akdlm/software/arcgispro/current/InstallCatalog.xml?downloadID=NA&type=NA&agolUsername=NA&receiptId=downloads.arcgis.com&__gdb__=1484350575_2321b9de31325a928cbd1c5b8770269a&ext=.xml12:36:15: Received REST redirection response.12:36:15: Downloaded started...12:36:14: Attempting to open connection to: https://downloads.arcgis.com/dms/rest/update/secured/InstallCatalog.xml?folder=software/arcgispro/current&token=nHE-RZRE1e79HnLdQQdVngeMaX2tSo8UG0Hl4_rVHeBRHQlZc_-rqYX1QnqQHRBQYJ4xlePsicXa4qJzqnE9n5MNWVgHzbfJRqtbOzvyLjT0XYOVUzQRTEN618pFlJvEiPr-uD5At_APjKGzuuNsojinytPAm_2XB8s6PN7LoYi-ljO2Jtf8X1ZpJy4183fLU7sNz8EypOLn2kDNzWePRg..&type=catalog12:36:14: REST argument [path] = software/arcgispro/current12:36:14: REST server URL = https://downloads.arcgis.com/dms/rest/update/secured/12:36:14: Setting AGOL token12:36:14: Checking Server Status.12:36:14: Updater client identified as ArcGISPro12:36:14: Root packageID identified as 2
Has anyone come across this problem yet?
Hey, did you find any solution to this Mr. Cyrus Blankinship ? Thanks
Here is the support doc from Microsoft about error code 1603: https://support.microsoft.com/en-us/kb/834484.
My guess is it's a permissions issue. Make sure you're running the update as an administrator. You can also try uninstalling 1.3 before installing 1.4.
