Stumbled across this issue again. Solution: Create a continuous raster with value = 0. Run Cell statistics with all desired rasters, including the continuous raster. The Overlay Statistic = "Sum". Be sure to set "processing extent" in environment settings to "Union of Inputs".
In the environment settings (at the bottom of raster calculator) set the processing extent to Union of Inputs.
Easy fix: use Cell Statistics tool. Select SUM as your 'Overlay Statistic' and check the Ignore NoData in calculations box
This was exactly what I was looking for, thank you so much!
