I'm getting an "Invalid token" message with Error 498 when I click the download link. Above the error it shows "ArcGIS Geowarehouse" with a "Home" link. Clicking the Home link brings up, "Services Directory is disabled" with Error 403. I've tried this with different browsers and even different Internet connections with no difference. What's going on?Edit: I discovered that the download link at the bottom by Code Attachment works. The link in Step 1 of how to use the template is the one causing problems.
I have replaced the logo but I can't see it. I replace it with a PNG image is there anything else that I have to do to see my new image.
Are you using Internet Explorer? I'm having the same problem with my logo image not appearing but that's only in IE; other browsers show the logo image properly. The 1.3.1 version of the template displays my logo without problems, and the 1.4 version displays the default logo fine in IE but not my own logo. Very strange.
I also used the 1.3 version and I didn't have problems with it. I know I figure it was the explorer because there some instances in which when I refresh the page the logo shows but then when you open it again is gone. Hope that somebody out there can find a solution to this annoying little problem.
What version of IE are you using?Some versions of IE don't display PNG files with transparency correctly. If possible can you try making it a GIF? or if it doesn't have transparency can you change it to a JPG?
I'm using IE 8. But let me emphasize that this problem did not occur with the 1.3.1 version of the map gallery template. It showed up with the 1.4 version. Same browser, same logo graphic file, different template.
Ok. I'll investigate this and see what I can find. Can you attach the image you're using so I can see what is happening?
Matt,Thanks very much. I'm attaching the image.Marc
pmgConfig.footerLogo = 'graphics/logo/RockvilleLogo.png';
pmgConfig.footerLogo = 'http://maps.rockvillemd.gov/gallery/graphics/yourLogo.png';
pmgConfig.footerLogo = '/gallery/graphics/yourLogo.png';
Did you put the image in your logo folder? Are you linking to it like this?pmgConfig.footerLogo = 'graphics/logo/RockvilleLogo.png';I put it in the logo folder and used that code and it was showing in IE 7 and IE 8. It may just be linked to wrong.Can you try linking to it like one of these following methods?pmgConfig.footerLogo = 'http://maps.rockvillemd.gov/gallery/graphics/yourLogo.png';pmgConfig.footerLogo = '/gallery/graphics/yourLogo.png';Hopefully it's one of those. Otherwise, i'll keep looking into it. 🙂Thanks for your help with this.
Matt,Very interesting that it worked for you. I actually never changed the code because I named my graphic as yourLogo.png. I sent it to you with Rockville in the name only so you would know what it is. Anyway, using the /gallery/graphics... path did not help. I can't use the external URL path yet since I'm working on the configuration on my local desktop machine. In case it matters, my OS is Windows 7 64-bit.Another thing going on with IE, perhaps unrelated, is that the gallery page loads extremely slowly and when I open the error message from the status bar in IE, I get the following:Webpage error detailsUser Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; Media Center PC 6.0; MDDR; .NET4.0C; .NET CLR 3.5.30729; .NET CLR 3.0.30729)Timestamp: Thu, 1 Dec 2011 21:51:05 UTCMessage: Access is denied.Line: 4Char: 12073Code: 0URI: file:///C:/GIS/Web_mapping/LocalGov_Portal/public-maps-gallery-1.4/public-maps-gallery/scripts/plugins/modernizr.min.jsThanks,Marc
Hi Mark,Yes, that error only occurs when running the webpage from the local filesystem in IE. It's probably what's causing the PNG image to not display as well.If you run the file from a web server, IE will not have that error. It's just IE's security not allowing the script to run from the local filesystem.
I'm running IE version 8, I have tried the JPG and GIF with no luck. I have also tried the following in the IE - Clear temporary internet files- I have verified that the show pictures option is turn on- I have check for enabling scripting, ActiveX, cookies and java programs(are on)- I have enable the Auto select encoding opition and check if is set to correct language.So, any more ideas,Thank you, so much
I have two issues to raise regarding the update from the 1.3.1 version of the map gallery template to the 1.4 version.First, the method of adding a title to the banner has changed. It used to be a graphic and now it is a text string. I see how that makes things easier but I have lost my logo and preferred font. What is the best way to get back to the logo and font I would prefer to have? Bear in mind I know pretty much nothing about CSS, and I'm guessing that I will need to make some adjustments in that area. Here are the two versions to see the comparison.1.3.1 -- http://maps.rockvillemd.gov/gallery1.4 -- http://maps.rockvillemd.gov/gallery14Second, when 1.3.1 was released I gave some feedback that it would be good if the legend would respect scale dependencies and only show the legend symbology for the map's current scale. This appears not to have been done. What is the status of this?Example (streetlights map in the gallery): http://maps.rockvillemd.gov/gallery/map.html?webmap=da37c709d83c4a398993dd5972951f52Thanks,Marc
Hey Marc,Thanks for the feedback.1. Yes, we made it a text string to simplify things. You can change the font with CSS but if it's a custom font you're wanting to use, you may have to use a webfont. Otherwise, just changing the value with CSS is fine. It's in global.css line 176.I'll see if I can do an update where you can either choose text or an image to use as the banner via the config. That would solve this problem. Some people will just choose text because it's easier. We tried to make this version easier for non technical people to set up.2. There are a couple different ways to render the legend I think. I think it depends on the kind of data and how it's stored. I'll have to look into this more but I'm not sure what I can do.This map legend does change when zooming in/out so it's something to do with that map.http://maps.rockvillemd.gov/gallery/map.html?webmap=4a176c17c322483bb857c18cf6df059a
Hi,My gallery: http://46.137.167.81//public-maps-gallery/index.htmlI'm using the mapViewer of ArcGIS.com:// CHANGES THE MAP VIEWER TO USE 'simple' (map.html), 'explorer' (ArcGIS Explorer) or 'arcgis' (ArcGIS Javascript)pmgConfig.mapViewer = 'arcgis'; // values: 'simple', 'explorer' or 'arcgis'. default: 'simple'.The gallery generates a wrong URL to ArcGIS.com:http://arcgis.com/home/webmap/viewer.html?webmap=8969ca7d9cc64cb083876ff519912f80(without www)When there is a feature layer in the map editing will be not available (without the www)The URL has to be: http://www.arcgis.com/home/webmap/viewer.html?webmap=8969ca7d9cc64cb083876ff519912f80Where to change the URL setting in the code?Thanks,Marco
pmgConfig.arcgisPortalURL = 'http://arcgis.com/';
OK - most of the functionality which is built into the new version, we appreciate. That being said I have one major issue and one minor.MAJOR ISSUE: It seems that mobile users are not being redirected to the their respective mobile apps. I don't care if the index3 is brought back or the redirect is from idex, but we really need it. It seems that some of the code is still in there but not all; perhaps I am missing something... help plz.MINOR ISSUE: The graphics formatting keeps changing. We will always default to our personal logos, fonts, branding, yadda yadda ... I wish esri would quit being so controlling in this regard. The idea is to make it personable, etc. I would much rather have more control over layout and such and imbed an esri logo than be constantly steered into whatever direction. When I go to the grocery store to buy milk and sugar - i buy milk and sugar; i don't care how many times they change the store:) It just so happens to be that the milk and sugar in this case is our look, our font, our logo (on top ribbon!) etc. I do believe that it is important to give ESRI credit and for their logo to be included. But esri is an intermediary; it is ESRI's job to generally help gis users put out product to the consumers. The extent to which it is beneficial for all the templates to have the same look and feel is suspect and i believe the more personable the product is the greater the success of the template and the more restrictive - the inverse. While the current iteration has simplified many elements, it is kinda restrictive and we will likely always cut out a lot and hard-code back w/ html. btw: reactivating the mobile facet is really important to us and would be greatly appreciated if someone could help me in this regard or have 1.4x come out and reinstate it... We are trying to mix and match from 1.3 and 1.4 and not being familiar with all this would be way easier to remove functionality that we don't want than to add it back from some previous version...
// USE ARCGIS iOS APP LINKS FOR USERS ON iOS DEVICES. Default: false. pmgConfig.mobileAppLink = true;
Hi. With the 1.3.1 version I was able to place layer packages within my ArcGIS Online map gallery group and the layer package would be available for downloading on the right side of the page. Version 1.4 shows additional maps where Version 1.3.1 showed layer packages. How do I get my layer packages available in Version 1.4 as they are in Version 1.3.1
How do I configure the file to open with ArcGISexplorer as the viewer map?
// CHANGES THE MAP VIEWER TO USE 'simple' (map.html), 'explorer' (ArcGIS Explorer) or 'arcgis' (ArcGIS Javascript) pmgConfig.mapViewer = 'simple'; // values: 'simple', 'explorer' or 'arcgis'. default: 'simple'.
