hi !I've posted the info on the forum, so other users can also profit from the work.try an approach like this :classification 1 : VOLUMEShttp://forums.arcgis.com/threads/51733-classification-approach-towards-(volumetric)-multiPatch-dataclassification 2 : SURFACE ORIENTATION(use a comp(f) to go from the classified volumes to each polygon)http://forums.arcgis.com/threads/51546-Calculating-shape-slopesclassification 3 : SURFACE DIMENSIONfor each single polygon, test the dimension and accordingly trigger e.g. the texturing of- flat roof surface- facade- metal box surface- ..it all looks a little complex, but once you have a good rule set, you can run this rule over any number of buildings and get good texturing completely automatted. I guess in your case this approach is VERY promising.cheers !:cool:
I have gotten an other input concerning �??ArcGIS Explorer does not support 3D display�?�.-->It does�?� Are you using ArcGIS Explorer Online (which is 2D-only), or did you miss the button on the toolbar which switches from 2D to 3D?
hi Larry. sadly, I'm not yet very familiar with ArcGIS products .. where do I find those 'referencedâ?? images im ArcGlobe ? * * * [ATTACH=CONFIG]12114[/ATTACH] * * * Okay, let me explain how this workflow would work in the CityEngine, what works and what does not, and what the role of metadata would play.
