I am not sure what I am doing wrong.
I can edit but nothing shows up in the dgrid.
I am not sure if the code below will post properly here is the script in Edit fiddle - JSFiddle
Any suggestions?
<!DOCTYPE html>
<html>
<head>
<title>Emergency Loc</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
<style>
html, body {
height: 100%;
width: 100%;
margin: 0;
body {
background-color: #fff;
overflow: hidden;
font-family: Helvetica, san-serif;
#templatePickerPane {
width: 225px;
overflow: hidden;
#panelHeader {
background-color: #92A661;
border-bottom: solid 1px #92A860;
color: #FFF;
font-size: 18px;
height: 24px;
line-height: 22px;
margin: 0;
overflow: hidden;
padding: 10px 10px 10px 10px;
#map {
margin-right: 5px;
padding: 0;
.esriEditor .templatePicker {
padding-bottom: 5px;
padding-top: 5px;
height: 500px;
border-radius: 0px 0px 4px 4px;
border: solid 1px #92A661;
.dj_ie .infowindow .window .top .right .user .content, .dj_ie .simpleInfoWindow .content {
position: relative;
.dgrid { border: none; height: 100%; }
.dgrid-column-0 {
width: 35px;
.dgrid-row-odd {
background: #FFFDF3;
td div img:hover {
cursor: pointer;
</style>
<script src="https://js.arcgis.com/3.15/"></script>
<script>
var map, grid;
require([
"esri/config",
"esri/map",
"esri/SnappingManager",
"esri/dijit/editing/Editor",
"esri/layers/FeatureLayer",
"esri/tasks/GeometryService",
"esri/toolbars/draw",
"dojo/keys",
"dojo/parser","esri/layers/ArcGISDynamicMapServiceLayer","dojo/_base/declare","dgrid/OnDemandGrid","dgrid/Selection","esri/symbols/SimpleFillSymbol","esri/Color","dijit/form/Button",
"esri/symbols/SimpleMarkerSymbol","dojo/_base/array",
"dojo/i18n!esri/nls/jsapi",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/domReady!"
], function (
esriConfig, Map, SnappingManager, Editor, FeatureLayer, GeometryService,
Draw, keys, parser,ArcGISDynamicMapServiceLayer,declare,Grid,Selection, SimpleFillSymbol,Color,Button,SimpleMarkerSymbol, arrayUtils, i18n
parser.parse();
//snapping is enabled for this sample - change the tooltip to reflect this
i18n.toolbars.draw.start += "<br/>Press <b>CTRL</b> to enable snapping";
i18n.toolbars.draw.addPoint += "<br/>Press <b>CTRL</b> to enable snapping";
//This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
//replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
//for details on setting up a proxy page.
esriConfig.defaults.io.proxyUrl = "/proxy/";
//This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
<!--____________________________________________Dgrid________________________________________________________________--!>
var StatesGrid = declare([Grid, Selection]);
var columns = [{
label: "", //wasn't able to inject an HTML <div> with image here
field: "ObjectID",
formatter: makeZoomButton
label: "Location",
field: "Location"
label: "Call Type",
field: "CallType"
//restrict sorting to the state name field
for (var i = 0; i < columns.length; i++) {
if (i == 1) {
columns.sortable = true;
} else {
columns.sortable = false;
grid = new StatesGrid({
bufferRows: Infinity,
columns: columns
}, "grid");
<!--____________________________________________Script________________________________________________________________--!>
map = new Map("map", {
basemap: Layer4,
center: [-122.710375, 42.197994],
zoom: 14
map.on("layers-add-result", initEditing);
var Layer4 = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.ashland.or.us/arcgis/rest/services/pictometry3inch/MapServer", {
opacity: 1
map.addLayer(Layer4);
var Layer7 = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.ashland.or.us/arcgis/rest/services/sandbox/EmerLoc/MapServer", {
visible: true,
refreshInterval: 0.3
Layer7.setVisibleLayers([1]);
map.addLayer(Layer7);
var operationsPointLayer = new FeatureLayer("http://gis.ashland.or.us/arcgis/rest/services/sandbox/EmerLoc/FeatureServer/0", {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["*"]
map.addLayers([operationsPointLayer]);
map.infoWindow.resize(400, 300);
function initEditing (event) {
var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
return {
"featureLayer": layer.layer,
"isEditable": true,
'showAttachments': true,
"showDeleteButton": false,
"fieldInfos": [{
'fieldName': 'Caller_Name',
'isEditable': false,
'tooltip': 'Caller Name',
'label': 'Caller Name:'
'fieldName': 'Priority',
'isEditable': true,
'tooltip': 'Priority',
'label': 'Priority:'
'fieldName': 'Location',
'label': 'Location:'
'fieldName': 'Phone',
'label': 'Phone:'
'fieldName': 'Notes',
'label': 'Notes:'
'fieldName': 'CallType',
'isEditable': true,
'label': 'CallType:'
var settings = {
map: map,
layerInfos: featureLayerInfos
var params = {
settings: settings
/* var editorWidget = dijit.byId('editorDiv');
if (editorWidget) {
editorWidget.destroyRecursive(true);
var editorWidget = new Editor(params, 'editorDiv');
editorWidget.startup();
//snapping defaults to Cmd key in Mac & Ctrl in PC.
//specify "snapKey" option only if you want a different key combination for snapping
map.enableSnapping();
//add the states demographic data
var statesLayer = new FeatureLayer("http://gis.ashland.or.us/arcgis/rest/services/sandbox/EmerLoc/MapServer/0", {
mode: FeatureLayer.MODE_SELECTION,
outFields: ["OBJECTID", "Priority", "Location", "last_edited_date","CallType"]
//create Selection Symbol
var highlightSymbol = new SimpleMarkerSymbol({
"color":[0,112,255,255],
"size":10,
"angle":0,
"xoffset":0,
"yoffset":14,
"type":"esriSMS",
"style":"esriSMSDiamond"
statesLayer.on("load", function(evt) {
var query = new Query();
query.where = "1=1";
evt.layer.queryFeatures(query, function(featureSet) {
var items = array.map(featureSet.features, function(feature) {
return feature.attributes;
//idProperty must be set manually if value is something other than 'id'
var memStore = new Memory({
data: items,
idProperty: "ObjectID"
window.grid.set("store", memStore);
window.grid.set("sort", "Location");
grid.on(".field-ObjectID:click", function(e) {
//retrieve the ObjectId when someone clicks on the magnifying glass
if (e.target.alt) {
zoomRow(e.target.alt);
map.addLayers([statesLayer]);
function makeZoomButton(id) {
//set the feature 'id' as the alt value for the image so that it can be used to query below
var zBtn = "<div data-dojo-type='dijit/form/Button'><img src='images/zoom.png' alt='" + id + "'";
zBtn = zBtn + " width='18' height='18'></div>";
return zBtn;
//center at the selected feature on the map from the row in the data grid
function zoomRow(id) {
statesLayer.clearSelection();
query.objectIds = [id];
statesLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(features) {
//re-centre map to zoom to the selected feature
map.centerAt(features[0].geometry); //using centerAt()
//map.centerAndZoom(features[0].geometry, 14); //using centerAndZoom()
</script>
</head>
<body class="claro">
<div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
</div>
<div data-dojo-type="dijit/layout/ContentPane" id="templatePickerPane" data-dojo-props="region:'left'">
<div id="grid"></div>
<div id="panelHeader">
Default Editor
</div>
<div style="padding:10px;" id="editorDiv">
</div>
</div>
</div>
</body>
</html>
