import arcpy Workspace = "in_memory" arcpy.env.overwriteOutput = True arcpy.env.workspace = Workspace #variables network = arcpy.GetParameterAsText(0) netHydroFC_path = arcpy.GetParameterAsText(1) nonNetHydroFC = arcpy.GetParameterAsText(2) accumSourceField = arcpy.GetParameterAsText(3) accumTargetField = arcpy.GetParameterAsText(4) calculateMe = arcpy.GetParameterAsText(5) #get the text name of the network FC without the full path by taking what's after the last "\" netHydroFC = netHydroFC_path.split("\\")[-1].strip() #list fields to include in cursor fields = ("OBJECTID", accumSourceField, accumTargetField) arcpy.AddMessage("Running...") #open arcpy.da cursor with arcpy.da.UpdateCursor(nonNetHydroFC, fields) as rows: for row in rows: #get values for each row rowObjID = row[0] rowCtchVal = float(row[1]) DAval = float(row[2]) #If there's already an accumulated value skip that record if DAval <> int(calculateMe): arcpy.AddMessage("ObjectID " + str(rowObjID) + " is already calculated") #If the value is equal to the "calculate me" flag run the operation if DAval == int(calculateMe): arcpy.AddMessage("Calculating ObjectID # " + str(rowObjID)) #make a feature layer in memory and select the record that is active in the cursor arcpy.MakeFeatureLayer_management(nonNetHydroFC, "sel_lyr") selection = '"OBJECTID" = {}'.format(rowObjID) arcpy.SelectLayerByAttribute_management("sel_lyr", "NEW_SELECTION", selection) #create a point at the start vertex of the selected record arcpy.FeatureVerticesToPoints_management("sel_lyr", "flag", "START") #select the upstream network & take the line layer from the returned layer group (network + junctions) flag = "flag" arcpy.TraceGeometricNetwork_management(network, "netLayer", flag, "TRACE_UPSTREAM") usSelection = arcpy.SelectData_management("netLayer", netHydroFC) field = accumSourceField usVals = [r[0] for r in arcpy.da.SearchCursor(usSelection, (field))] sumUSVals = float(sum(usVals)) newDAVal = float(sumUSVals + rowCtchVal) row[2] = newDAVal rows.updateRow(row)
Don't know if you're still looking for this, but I ended up scripting something using the Geometric Network tools (available as a toolbox in 10.1) and an arcpy.da cursor. It takes a while to run (~30hours to run my stream network of 410,000 segments) but that's actually a little faster than the performance I was getting using ArcHydro's Accumulate Attributes. Let me know if you're still interested...
I notice the last post on this topic was from January. Has anybody come across a script that can automate the accumulate attributes process? Jon
