I am trying to create breaks in a csvlayer to differentiate points in my data by color or size. Ideally, I would be able to do something similar to what is in the tutorial found here: Class breaks renderer | ArcGIS API for JavaScript 3.22 . However, this doesn't seem to work as all the points are displayed as the same color. The code posted below is what I am currently working with.
Thank you,
Nathan
Hi there,
You have to pass in an instance of symbol to addBreaks method. You are passing in a color object in your code.
I modified your test app.
-Undral
Here is the code that I am trying to run. When I run this, all of the points are the same color.
