We tried to compile sample widget "WeatherUndergroundWidgetCS" and we got the same issue. By the way, our version of Operations Dashboard and SDK WPF are 10.2.3. Does anyone else come across the same problem? Thanks!
Chen
i'm getting the same error. BTW, Cornelia, did you try to Add you addin to the Operations Dashboard. I think you will face a problem while doing that. 'cause even if you managed to compile without an error, it misbehaves while adding to the dashboard.
I'm stuck on the same problem while trying to run the CountWidget from the Sample projects. Any workaround would help. I got a small customization with a tight deadline.
The error should only be because the sample unfortunately still references the old SDK - as Dom suggested, please try unloading and editing the project file (csproj) to update the reference to the latest version:
<PropertyGroup> <!--depending on 32bit or 64bit machine the reg key for the IDEIntegration folder is different--> <ReferenceFolder32>$(registry:HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\ArcGISRuntimeWPF10.1.1@InstallDir)SDK\OperationsDashboard</ReferenceFolder32> <ReferenceFolder64>$(registry:HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ESRI\ArcGISRuntimeWPF10.1.1@InstallDir)SDK\OperationsDashboard</ReferenceFolder64> <!--set ReferenceFolder depending on 32bit or 64bit machine--> <ReferenceFolder Condition="Exists('$(ReferenceFolder32)')">$(ReferenceFolder32)</ReferenceFolder> <ReferenceFolder Condition="Exists('$(ReferenceFolder64)')">$(ReferenceFolder64)</ReferenceFolder> </PropertyGroup>
Cheers
Mike
