I am not able to access it.
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="FeatureLayer on demand"> <!-- This sample shows you how to add InfoWindows to a feature layer. When user clicks on one of the polygon features, the info window popup will show. --> <s:layout> <s:VerticalLayout/> </s:layout> <fx:Style> @namespace s "library://ns.adobe.com/flex/spark"; @namespace mx "library://ns.adobe.com/flex/mx"; @namespace esri "http://www.esri.com/2008/ags"; esri|InfoWindow { skin-class: ClassReference("your.path.to.InfoWindowSkin"); } </fx:Style> <fx:Script> <![CDATA[ import mx.controls.Alert; import mx.events.FlexEvent; protected function map1_creationCompleteHandler(event:FlexEvent):void { if (map.infoWindow) { map.infoWindow.addEventListener("onSubmitClick", onInfoWindowSubmitClick, false, 0, true); } } protected function onInfoWindowSubmitClick(event:Event):void { Alert.show("submit button clicked", "! ! !"); } ]]> </fx:Script> <esri:Map id="map" openHandCursorVisible="false" creationComplete="map1_creationCompleteHandler(event)"> <esri:extent> <!-- Extent for Bloomfield Hills, Michigan --> <esri:Extent xmin="-9271300" ymin="5247400" xmax="-9270300" ymax="5248500"> <esri:SpatialReference wkid="102100"/> </esri:Extent> </esri:extent> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <esri:FeatureLayer id="fLayer" mode="onDemand" outFields="[PARCELID,OWNERNME1,SITEADDRESS,LNDVALUE,USECD]" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer/2"> <esri:symbol> <esri:SimpleFillSymbol id="fillsym" style="null"> <esri:SimpleLineSymbol width="3" color="0xFF0000"/> </esri:SimpleFillSymbol> </esri:symbol> <esri:infoWindowRenderer> <fx:Component> <mx:VBox backgroundColor="0xffffff" color="0x444444" label="Parcel {data.PARCELID}"> <mx:Label text="Owner: {data.OWNERNME1}"/> <mx:Label text="Address: {data.SITEADDRESS}"/> <mx:Label text="Land Value: {data.LNDVALUE}"/> <mx:Label text="Landuse: {data.USECD}"/> </mx:VBox> </fx:Component> </esri:infoWindowRenderer> </esri:FeatureLayer> </esri:Map> <s:Label enabled="{fLayer.loaded}" text="Using the 'onDemand' mode, parcels are fetched 'as needed' when you pan and zoom. Click any parcel to see more information."/> </s:Application>
<fx:Metadata> /** * A strongly typed property that references the component to which this skin is applied. */ [HostComponent("com.esri.ags.components.supportClasses.InfoWindow")] [Event(name="onSubmitClick", type="flash.events.Event")] </fx:Metadata> ... <fx:Script> <![CDATA[ /** * Listen submit button click */ protected function onSubmitButtonClick(event:MouseEvent):void { dispatchEvent(new Event("onSubmitClick", true, false)); } ]]> </fx:Script> ... <s:HGroup id="headerGroup" width="100%" includeInLayout.withoutHeader="false" minWidth="0" verticalAlign="middle" visible.withoutHeader="false"> <esri:InfoWindowLabel id="labelText"/> <s:Rect width="100%" height="10" minWidth="0"/> <esri:InfoWindowCloseButton id="closeButton"/> <s:Button id="submitButton" click="onSubmitButtonClick(event)" label="Submit"/>
