Hi, is there a version for Flex 3 SDK ? specifically 3.6A that comes with Flash builder 4?
I googled it and all what I found is flex 4 using the spark components only.
Unfortunately, as per the below link:
ArcGIS Viewer for Flex
also I checked the code you sent me and it requires Flex 4 SDK as well otherwise I get lots of compilation errors. also if I decided to use a version lower than v2.5 will it have the openstreetroad support ? (probably not)
do you recommend going lower than v2.5 or it is going to be a waste of time?
Ahmed,
If I remember correctly the Flex 2.5 API is what you are looking for then.
I'm looking for Esri Flex API that works with Adobe Flex SDK v3.6A all, the
current ESRI flex downloads are for Adobe Flex 4 SDK only.
thanks for the quick reply.
On Wed, Apr 15, 2015 at 8:14 AM, Robert Scheitlin, GISP <geonet@esri.com>
Are you looking for the Adobe Flex SDK or the Esri Flex API?
