I believe this is ever since the 2.2 update, but has anyone else noticed their database connections always being disconnected upon opening a project? I have to re-add them every time and they do not save.
Have you been using Pro for multiple versions at this point?
If so, has this ever occurred in a previous version?
What type of database are you connecting to (e.g. SQL Server, Oracle, other) and specific version?
Yes multiple versions and it has never occurred before. Using SQL Server and 2 different connections (OS and named admin user).
What happens when you add some SDE layers to a MXD, and import the MXD into a new Pro project?
Hi Ben,
We had this problem recently, some users on 2.1 as well as 2.2. There is still a bit of mystery behind it because it was happening inconsistently between different users with same/similar configurations (some didn't have issue). We were able to see the issue on Win 7 and 10. Upgrading the SQL client (currently on 11.4.7) fixed the issue for all but one user. So when I say there is a bit of mystery... the one user eventually started working as well, but we're not sure why. Possibly older configuration lingering through multiple Pro upgrades that finally got resolved on a restart...?
Ultimately you'll want to make sure you have latest Pro version as well as SQL client, see if that works and if not report back here and we can compare notes. I'd be curious to see this solve the issue for others (or not).
Rob
Yes! This was the fix for me. I believe this behavior started at 2.2 and was not constant among all my users. So far my machine was the only one affected by this. Updating to ODBC driver 11 has solved the problem. Thanks for sharing your issue and input everyone. A win for the forum today!
Did you guys find a solution? We're now having this issue on 2.8.
Having a similar issue in version 3.2.1, where in the middle of editing layers in a map that is was working fine for hours, randomly all the data connections say they are broken. Closing and opening the map again fixes the issue but it is infuriating.
I am having a similar issue on Windows 10 Enterprise with ArcGIS Pro 3.3. In addition to the cloud connections not saving in the project, when I try to add them back, some will add and some will not and I can not figure out why.
Yes, i am using 3.2.1 I believe.. and having the same issue. Broken data each time I open a map. The connections LOOK connected but are not. It prefers me to delete the existing db connection before replacing it. If I look at its connection properties and reenter the password it still doesn't re-connect. i have to add a new db connection.
