Is there a way to get the total count of features in a single service with python?
See: Query (Feature Service)
The Query operation is performed on a feature service resource. The result of this operation is either a feature set for each layer in the query or a count of features for each layer (if returnCountOnly is set to true) or an array of feature IDs for each layer in the query (if returnIdsOnly is set to true).
I did a quick test, with returnCountOnly set to true and using a where "1=1". It returned a count.
URL <SPAN class="operator token">=</SPAN> <SPAN class="string token">"https://services.arcgis.com/xyz/arcgis/rest/services/myFeature/FeatureServer/0/query"</SPAN> query_dict <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"where"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"1=1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"returnCountOnly"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"true"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"returnGeometry"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"false"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"f"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"json"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"token"</SPAN><SPAN class="punctuation token">:</SPAN> token<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'token'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN> jsonResponse <SPAN class="operator token">=</SPAN> urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>URL<SPAN class="punctuation token">,</SPAN> urllib<SPAN class="punctuation token">.</SPAN>urlencode<SPAN class="punctuation token">(</SPAN>query_dict<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> response <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>jsonResponse<SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> response <SPAN class="comment token"># prints: {u'count': 486, u'serverGens': {u'serverGen': 461482, u'minServerGen': 65364}}</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
If you are using the Python API, see: arcgis.features.FeatureLayer.query
and use return_count_only=True
