<GuidAttribute("EBAF6DBE-7E4F-45F8-B56B-AD9024E5F46A"), _ ClassInterface(ClassInterfaceType.None), _ ProgId("AGISExtension.cAGISExtension"), _ ComVisible(True)> _ Public Class cAGISExtension Implements IAGISExtension Implements ESRI.ArcGIS.esriSystem.IExtension
#Region "COM Registration Functions" ' Add the registration funcions that will be executed when ESRIRegAsm is ' run on the generated dll. This will register with the ArcMap ' extensions category. <ComRegisterFunction(), ComVisible(False)> _ Shared Sub RegisterFunction(ByVal registerType As Type) Dim regKey As String = String.Format("HKEY_CLASSES_ROOT\CLSID\{{{0}}}", registerType.GUID) MxExtension.Register(regKey) End Sub <ComUnregisterFunction(), ComVisible(False)> _ Shared Sub UnregisterFunction(ByVal registerType As Type) Dim regKey As String = String.Format("HKEY_CLASSES_ROOT\CLSID\{{{0}}}", registerType.GUID) MxExtension.Unregister(regKey) End Sub #End Region
