function initSelectToolbar() { var selectQuery = new esri.tasks.Query(); dojo.connect(map, "onClick", function (evt) { var layerInfos = hydrMSL.layerInfos; var visible = hydrMSL.visibleLayers; for (var i = 0; i < layerInfos.length; i++) { layer = layerInfos; if (visible.indexOf(layer.id) > -1) { var FL = find_in_array(FLayers, layer.id); FL.setSelectionSymbol(selectionSymbol); selectMode; if(evt.ctrlKey) { selectMode = esri.layers.FeatureLayer.SELECTION_SUBTRACT; } else { selectMode = esri.layers.FeatureLayer.SELECTION_ADD; }; var centerPoint = new esri.geometry.Point (evt.mapPoint.x, evt.mapPoint.y, evt.mapPoint.spatialReference); var mapWidth = map.extent.getWidth(); //Divide width in map units by width in pixels var pixelWidth = mapWidth / map.width; //Calculate a 10 pixel envelope width (5 pixel tolerance on each side) var tolerance = 10 * pixelWidth; //Build tolerance envelope and set it as the query geometry var queryExtent = new esri.geometry.Extent (1, 1, tolerance, tolerance, evt.mapPoint.spatialReference); selectQuery.geometry = queryExtent.centerAt(centerPoint); //selectQuery.geometry = evt.mapPoint; FL.selectFeatures(selectQuery, selectMode, function (features) { if (features.length > 0) { } else { } }); // dojo.connect(FL, "onSelectionComplete", selectMode, function(){ // for (var x = 0; x < FLayers.length; x++) { // var selected = FLayers.getSelectedFeatures(); // var selected = FL.getSelectedFeatures(); // alert(selected.length); // for (i =0; i < selected.length; i++) // { // var row = selected; // } //}; // }); }; } }); function find_in_array(arr, value) { var FLayer; for (var i = 0, len = FLayers.length; i<len; i++) { if (arr.layerId == value) return FLayers; }; } };
