Whats the screen resolution you are working on?Just for a quick test try DPI 150, then 200 and 300 and see what happens !!!
Hey, I followed this http://resources.arcgis.com/en/help/runtime-java/concepts/index.html#/Printing/01qv00000084000000/ to set up a print button on my application. The only problem I am having is making the map fit on one page. any idea how do achieve this?
I am not very clear on what the exact problem is. Have you set up the Paper size and Orientation? How are you setting that?
Paper paper = new Paper(); // ...set up the paper options... PrinterJob printJob1 = PrinterJob.getPrinterJob(); PageFormat pageFormat = new PageFormat(); if (printJob1.printDialog()) { try {printJob1.print();} catch (PrinterException exc) { System.out.println(exc); } } //set up page format [DEFAULT] options and pass the paper settings through pageFormat.setPaper(paper); pageFormat.setOrientation(Integer.valueOf(PageFormat.LANDSCAPE)); // set page format for the map to print map.setPageFormat(pageFormat); printJob1.setPageable(map); try { // send job to printer! printJob1.print(); } catch (PrinterException e) { // handle the exception }
You can use the DPI option while printing to adjust printing according to the paper size int DPI = 96; // change DPI accordingly Paper paper = new Paper(); MediaSize size = sizeMap.get(sizeList.getSelectedItem()); double width = (size.getX(Size2DSyntax.INCH))*DPI; double height = (size.getY(Size2DSyntax.INCH))*DPI; paper.setSize(width, height); paper.setImageableArea(MARGIN, MARGIN, width - (2*MARGIN), height - (2*MARGIN)); I hope this helps
