I hosted Feature layer in Portal, created new field and would like to calculate field using Arcade expression. When I choose to calculate field I have no option to do it in Arcade.. How can I do it?
I have Portal 10.6.1 and I'm seeing the same behavior. I've published several feature layers for testing and can't get the Arcade editor to appear. When I click Calculate Field I am taken straight into the SQL editor and am not given an option to choose Arcade.
I read this and I've changed the editing settings on my layers based on the note under #4 but I can never use Arcade to calculate field values. Using Arcade for symbology via the Map Viewer works fine.
Liana Smith did you contact Esri support? What did they say?
That is strange. According to this help topic: Use Arcade expressions with Calculate Field—Portal for ArcGIS | ArcGIS Enterprise the Arcade expression should be available in your version. Can you reach out to Esri Support?
10.6.1
What version of Portal do you have?
