Interesting, by snapping do you mean digitizing? If you simply digitized, I would agree with you that you shouldn't see mis-close for the resulting parcels. Can you submit a incident for this and submit the parent parcel as a Cadastral XML? Chris
Well, I am trying to build a completely new parcel after deleting the inaccurate one, in this case the basis of bearing tool can't be used (it's grayed out). The survey I have uses true north, my coordinate system uses grid north, there is a rotation I can't account for when constructing a new parcel and trying to digitize the natural boundary with a line string off an ortho photo projected in my map.I tried creating a new parent parcel (a quarter-quarter section) and then constructing from parent so I could use the basis of bearing tool. I constructed new lines from the survey then digitized the natural boundary with a line string, using snapping so the parcel's closure was perfect. Everything looked good when I built the new parcel, but when I open it, there is a misclose. Not sure what is going on there.Ryan
