Hello Jose, did you manage to solve the problem?
I'm trying to modify the loaded.config so the tools will work with my own model, but i'm a bit lost....
Hi Marcela,
I was able to configure it. the config file (Loaded.config) is located in different folders following your operating system
Configure Attribute Assistant - Water Utility Network Editing | ArcGIS for Local Government
Jose, i've been abre to open the file, it's just that i'm not sure what to modify in the file, i don't know if i have to use the feature class name or it's alias. can you attach your modified file so i can take a look at it or post a screen shot?
thanks!
You need to use the feature class name
For example feature class Sewer Manholes (SManhole) has a field called Municipality ID (MUNICID) and gets populated with the value of the municipality polygon when it gets digitized.
