Thanks for your reply. I would be amenable to trying to your solution, but unfortunately I'm a little lost. I didn't do a dissolve, and am not sure how to "change the dissolve fields at the original lines." So, missing the first step, I can't continue with the rest. I don't have the original lines, as they were created and merged as I worked. The were not created based on any polygons, and there's no other spatial file that they're related to. I did, however, use the "Explode Multipart Feature" to separate the resultant lines after my split, and then merged the appropriate parts again. I would say the issue is solved.(Also, I still don't understand why this is the normal behavior for a split, why splitting in one location would cause a seemingly random split in another location, and the line fragments would be considered one line.)
The behavior is normal. You have dissolved to create a branching multi-part polyline, which will randomly append the order of the internal parts. Part 1 does not have to chain to part 2, etc. When you split the break in the internal part order becomes apparent. You would have to control the part assembly, which is a pain to do unless you wrote a python script.Anyway, I would do the splits on the original lines or a copy of them and change the dissolve field values at the original lines. Then use the Buffer tool with a very small buffer and the List option and uncheck the create multi-part option. Then use Spatial join with the One To Many option to get the polygon Join ID as a new group ID for every set of lines. Select where the original line attributes equaled the lines and do a new dissolve on the new group ID and the old group ID with the create multi-part feature option checked. These will create contiguous new branching groups.
Hi there,I've got a line feature that was created by merging multiple sections of line. I'm trying to split it back up in different places, and when I do, I get multiple splits and lines that are considered one line but are not connected. The image here shows the location I placed the point in a yellow circle. The highlighted line shows one of the resultant lines, while the pink is the other. [ATTACH=CONFIG]26522[/ATTACH]Is there something I'm missing? I've tried repairing the geometry just in case. I've also made sure nothing else is selected, turned off other layers, anything else I can think of.Thanks for any assistance!Sarah
