HiWe are migrating an application in 9.2 to version 10. The following VB code. NET converted to PDF in version 9.2 but returns a blank page used in Arcgis 10. Anyone know how to export to PDF the active layout (SDK. NET ArcGis 10)?Thanks in advance (JMJ98)'------------------------'variables Dim lScrRes As Long Dim pExporter As IExporter Dim deviceRECT As tagRECT Dim pDriverBounds As IEnvelope Dim pCancel As ITrackCancel Dim nomExportacio As String Dim pExport As IExport Dim iScreenResolution As Integer Dim iOutputResolution As Integer Dim exportRECT As tagRECT Dim pPixelBoundsEnv As IEnvelope Dim hdc As Long Dim deviceFrameRect As tagRECT Dim pActiveView As IActiveView Dim tmpDC As Long Dim faExportacio As Boolean Dim formatoImagen As String Dim pMxDoc As IMxDocument Dim objFactory As IObjectFactory Dim nom As String Dim pageL As IPageLayout Dim map As IMap Dim psi As New ProcessStartInfo()'------------------------...... faExportacio = False pActiveView = pMxDoc.PageLayout pageL = New PageLayout pageL = pActiveView If formatoImagen = "PDF" Then pExporter = objFactory.Create("esriOutput.PDFExporter") nomExportacio = nom pExporter.ExportFileName = nomExportacio With deviceFrameRect .left = 0 .right = 800 .top = 0 .bottom = 600 End With 'pActiveView.ScreenDisplay.DisplayTransformation.DeviceFrame = deviceFrameRect tmpDC = GetDC(0) iScreenResolution = GetDeviceCaps(tmpDC, 88) '88 is Win32 constant for LOGPIXELSX ReleaseDC(0, tmpDC) iOutputResolution = 1200 pExporter.Resolution = iOutputResolution With exportRECT .left = pActiveView.ExportFrame.left * (iOutputResolution / iScreenResolution) .top = pActiveView.ExportFrame.top * (iOutputResolution / iScreenResolution) .right = pActiveView.ExportFrame.right * (iOutputResolution / iScreenResolution) .bottom = pActiveView.ExportFrame.bottom * (iOutputResolution / iScreenResolution) End With pPixelBoundsEnv = New Envelope pPixelBoundsEnv.PutCoords(exportRECT.left, exportRECT.top, exportRECT.right, exportRECT.bottom) pExporter.PixelBounds = pPixelBoundsEnv hdc = pExporter.StartExporting pCancel = New CancelTracker pActiveView.Output(hdc, iOutputResolution, exportRECT, pageL.Page.PrintableBounds, pCancel) pExporter.FinishExporting() faExportacio = True psi.FileName = System.Windows.Forms.Application.StartupPath.ToString & "\tmp\" & cmbParametro.Text & ".pdf" Process.Start(psi) End If'------------------------
HiThis sample runs me ok, inside ArcGis 10. But if runs in a windows form application (with automated arcgis opened), the result its blank PDF.Please, Anyone can you help me ??JMJ98Sample for SDK Argis 10:Public Sub ExportActiveViewParameterized(ByVal ExportFormat As String, ByVal iOutputResolution As Long, ByVal lResampleRatio As Long, ByVal bClipToGraphicsExtent As Boolean) 'Export the active view using the specified parameters Dim docActiveView As IActiveView Dim docExport As IExport Dim docPrintAndExport As IPrintAndExport Dim RasterSettings As IOutputRasterSettings Dim sNameRoot As String Dim sOutputDir As String Dim bReenable As Boolean If (GetFontSmoothing()) Then bReenable = True DisableFontSmoothing() If (GetFontSmoothing()) Then MsgBox("Cannot Disable Font Smoothing. Exiting.") Return End If End If docActiveView = My.ArcMap.Document.ActiveView ' Create an Export* object and cast the docExport interface pointer onto it. ' To export to any format, we simply create the desired Class here ExportFormat = "PDF" Select Case ExportFormat Case "PDF" docExport = New ExportPDF Case "EMF" docExport = New ExportEMF Case "BMP" docExport = New ExportBMP Case "EPS" docExport = New ExportPS Case "SVG" docExport = New ExportSVG Case "GIF" docExport = New ExportGIF Case "TIF" docExport = New ExportTIFF Case "JPEG" docExport = New ExportJPEG Case "PNG" docExport = New ExportPNG Case "AI" docExport = New ExportAI Case Else MessageBox.Show("Unrecognized output format, defaulting to EMF") ExportFormat = "EMF" docExport = New ExportEMF End Select docPrintAndExport = New PrintAndExport ' Output Image Quality of the export. The value here will only be used if the export ' object is a format that allows setting of Output Image Quality, i.e. a vector exporter. ' The value assigned to ResampleRatio should be in the range 1 to 5. ' 1 corresponds to "Best", 5 corresponds to "Fast" If TypeOf docExport Is IOutputRasterSettings Then ' for vector formats, assign a ResampleRatio to control drawing of raster layers at export time RasterSettings = docExport RasterSettings.ResampleRatio = lResampleRatio ' NOTE: for raster formats output quality of the DISPLAY is set to 1 for image export ' formats by default which is what should be used End If 'assign the output path and filename. We can use the Filter property of the export object to ' automatically assign the proper extension to the file. sOutputDir = System.Environment.GetFolderPath(Environment.SpecialFolder.Personal) + "\" sNameRoot = "VBExportActiveViewSampleOutput" docExport.ExportFileName = sOutputDir & sNameRoot & "." & Right(Split(docExport.Filter, "|")(1), _ Len(Split(docExport.Filter, "|")(1)) - 2) docPrintAndExport.Export(docActiveView, docExport, iOutputResolution, bClipToGraphicsExtent, Nothing) MessageBox.Show("Finished Exporting " & sOutputDir & sNameRoot & "." & Right(Split(docExport.Filter, "|")(1), _ Len(Split(docExport.Filter, "|")(1)) - 2) & ".", "Export Active View Sample") 'cleanup for the exporter docExport.Cleanup() If (bReenable) Then EnableFontSmoothing() bReenable = False End If End Sub
What do you mean by "if runs in a windows form application (with automated arcgis opened)"..Please can be clear on the same...or any screen ?
Hi (sorry for my english)From an application in VB.NET and try to open an ArcMap print your layout. (Automation) We have included the sample code (ExportActiveView) and get a blank PDF. In contrast, using the same example with ArcMap works perfectly.JMJ98
Somehow you have to play with focus pagelayout... not basically activeview...
I've not had a chance to step through the code yet but wanted to at least mention that the ArcPy site package has simple functions to export to pdf. We have documentation in the SDK regarding calling python scripts from .NET if this sounds like an alternative you may be interested in.
I don't have a solution for export from .NET aplication to PDF.VBA runs but the same code from my VB .NET application fails and returns a blank PDF. I think that error have a difficult solution ....Maybe its the moment of on arcpy thinking, and see if runs.
