I love the new storymaps interface. Will it be possible to embed the results? I'd love to use them within my Drupal website, adding the organization's branding and navigation.
Hi Jonathan -- Of course! You can use a story's link to embed it in a web page or blog.
In an update coming later this week we'll be adding an option to grab some preconfigured embed code for a story, but that's not needed; embedding works today.
Thanks for your quick reply! Unfortunately, adding the URL, as-is, won't work in the Drupal CMS. I need the embed code to which you referred. Glad you're working on that!
Hi Jonathan -- There won't be much that's magical about the embed code we will provide; you can create your own. Just use the story link as the "src" attribute in an iframe, like this:
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>iframe</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://storymaps.arcgis.com/stories/MYSTORYID<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>iframe</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
You can also set the frame size and other behaviors using other parameters supported in an iframe, but those are largely optional.
Otherwise, the Embed the story option should be available for you tomorrow in the header menu (the "..." menu) of any story shared with Everyone.
Thanks. That works, though not perfectly. I'll keep tweaking...
I'm excited to try the embed feature tomorrow. One more question: I saw the advice not to deploy the new-style storymaps to a wide audience since you all are still building. Does that advice still stand?
