Please see the following document that describes this issue in detail.http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/d/0001000001nn000000.htmSpecifically this section is of interest:Creating components�??In .NET, when you use the C# or VB.NET operator, it creates the object in the driving application's process space, not in the target application (for example, ArcMap) process. Often, what you really want is to create an object in the target application process space while accessing control of it from the driving application. This sort of control is made possible by the IObjectFactory interface, obtainable from the application object.After casting the application reference to IObjectFactory and using it to create the objects in the appropriate process space the export should no longer empty.
