Hello , I add a RasterLayer from JPG file , but there is a gray edge on this RasterLayer picture , how to remove the gray edge ? Thanks .
kishorg007@gmail.com
Can you give me your email , I give you my jpg photo file and screenshots in ArcMap and in ArcGIS Explorer . Thanks .
Trouble you to show screenshots. I don't know how to operate. Thank you.
Go to the image properties > symbology > Set 'Background color' to 'No color'
Or
Just save the image in .tif format and use it in the Arcgis explorer
Regards
Kishor
Thanks your answer , I take the same jpg file into Arcmap , there is not the edge in the ArcMap , but add into ArcGIS Explorer , there is the edge , We can see the edge is from ArcGIS Explorer and not from this jpg file self .
This , your said becouse the Transparent Color is not in jpg file , so this way can not remove the edge ..
I think it is sure have any set by ArcGIS Explorer Desk or by ArcGIS Explorer SDK code . Please give me these kind way . Thank you very much.
I have had good success with using the option to set a transparency color. (Tools, Appearance, Set Transparent Color, then click on the area you don't want drawn. Whatever color that pixel is won't be drawn for the rest of the image. Nice way to get rid of collars on images.
I hope use ArcGIS Explorer only , do not want use ArcMap.
Thanks your anser . This is my picture in photo shop , it has not gray edge , but adding in ArcGIS Explorer , these is gray edge . I do not want this gray edge .
if you have ArcMap, export the file using a smaller extent so that the border is clipped off...In arcexplorer...well, all it is an explorer and lacks functionality to do what you want
This is the RasterLayer.
It looks like the image was acquired with a border around it, where did it originate from? Since you are using arcexplorer, there are no image processing capabilities there so you may have to live with it unless you have access to other software which will retain any image georeferencing. If it isn't a georeferenced image, just bring it into a image package and crop it a bit
This is screen grab , I want remove these four gray lines . Thanks.
screen grab? perhaps it is just the nodata area if the image is slightly rotated. You will have to check the symbology for the layer to confirm
