Is it possible to represent water in motion, a river for example? Thank you Pedro Oliveira
/** * File: WaterMaterial.cga * Created: 30 May 2013 19:24:39 GMT * Author: Craig */
version "2013.1"
// A simple water texture rule with 5 different types - different colors, wave heights & speeds
@Order(1) @Range("River","Stream","Pond","Lake","Ocean")attr Water_Type = "River"
@Range(0, 1.0)@Order(2)attr r = .44@Range(0, 1.0)@Order(3)attr g = .55@Range(0, 1.0)@Order(4)attr b = .44
@StartRuleWater -->// __waterparams_scale_speed case Water_Type == "River" : set(material.name, "river__water__waterparams_5_10") color(.44,.55,.44) case Water_Type == "Stream" : set(material.name, "river__water__waterparams_5_30") color(.44,.55,.44) case Water_Type == "Pond" : set(material.name, "river__water__waterparams_1_3") color(.2,.4,.45) case Water_Type == "Lake" : set(material.name, "river__water__waterparams_4_8") color(.2,.4,.45) case Water_Type == "Ocean" : set(material.name, "river__water__waterparams_15_20") color(.2,.4,.45) else: X.
Hi there,Could you allow us access to download the cga file? It says that we don't have permission to access.Thank you sir!
Thank you, it worked.
greetings
Hi Pedro
Yes you can. There´s two options:
1. Choose one polygon and add to the end of the name " __water " : example myriver__water
A sample here http://bit.ly/2EWMpSR
2. Option two : Use the rule WaterMaterial.cga available on http://www.arcgis.com/home/item.html?id=067950a3a1f44129a10b3a458802e450
