I'm trying to have a GP tool link (ArcGIS API for JavaScript Sandbox) appears in the Robert's Popup Panel Widget https://community.esri.com/docs/DOC-7355 . I'm using the 2.1.1 version of the widget. How can I overwrite the map popup used in the widget?
Thank you for your help!
Lesi
Lesi,
In the Widget.js make these changes (add lines 25-33 and 43-47):
postCreate<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">inherited</SPAN><SPAN class="punctuation token">(</SPAN>arguments<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>popupMenu <SPAN class="operator token">=</SPAN> PopupMenu<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getInstance</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>featureActionManager <SPAN class="operator token">=</SPAN> FeatureActionManager<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getInstance</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>actionsPaneDiv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">own</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'mousedown'</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> event<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stopPropagation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">.</SPAN>altKey<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> msgStr <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>nls<SPAN class="punctuation token">.</SPAN>widgetverstr <SPAN class="operator token">+</SPAN> <SPAN class="string token">': '</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>manifest<SPAN class="punctuation token">.</SPAN>version<SPAN class="punctuation token">;</SPAN> msgStr <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="string token">'\n'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>nls<SPAN class="punctuation token">.</SPAN>wabversionmsg <SPAN class="operator token">+</SPAN> <SPAN class="string token">': '</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>manifest<SPAN class="punctuation token">.</SPAN>wabVersion<SPAN class="punctuation token">;</SPAN> msgStr <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="string token">'\n'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>manifest<SPAN class="punctuation token">.</SPAN>description<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Message</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> titleLabel<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>nls<SPAN class="punctuation token">.</SPAN>widgetversion<SPAN class="punctuation token">,</SPAN> message<SPAN class="punctuation token">:</SPAN> msgStr <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>popup <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>zt <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toDom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'<a title="Zoom" to="" class="action zoomTo" href="javascript:void(0);"><span>'</SPAN> <SPAN class="operator token">+</SPAN> esriBundle<SPAN class="punctuation token">.</SPAN>widgets<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN>NLS_zoomTo <SPAN class="operator token">+</SPAN> <SPAN class="string token">'</span></a>'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">place</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>zt<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>actionsListDiv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> link <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"a"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"class"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"action"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"id"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"statsLink"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"innerHTML"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Population"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">//text that appears in the popup for the link</SPAN> <SPAN class="string token">"href"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"javascript: void(0);"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>actionsListDiv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//when the link is clicked register a function that will run</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>calculatePopulation<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>clearSel <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toDom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'<a title="'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>nls<SPAN class="punctuation token">.</SPAN>clearseltip <SPAN class="operator token">+</SPAN><SPAN class="string token">'" to="" class="action clearSel" href="javascript:void(0);"><span>'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>nls<SPAN class="punctuation token">.</SPAN>clearsel <SPAN class="operator token">+</SPAN> <SPAN class="string token">'</span></a>'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">place</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>clearSel<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>actionsListDiv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> topic<SPAN class="punctuation token">.</SPAN><SPAN class="token function">subscribe</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"widgetsActionsRegistered"</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>_onWidgetsActionsRegistered<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">_createPopupMenuButton</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setEvtHandlers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">onWindowResize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> calculatePopulation<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> feature <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getSelectedFeature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"calc pop clicked"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you Robert!
