I changed the name of the widget from "Layer list" to "Select imagery to compare", but now the title is cropped "Select imagery to co..."
How do I make boundaries of the name field wider or change the font to a smaller one?
Diana,
Since you have the LayerList widget in the Foldable Theme and in the HeaderController Widgets widget pool,
open your apps config.json and make a change like this (line 9 add the comma and add line 10 with your desired width):
"widgetPool": { "panel": { "uri": "themes/FoldableTheme/panels/FoldablePanel/Panel", "position": { "top": 5, "right": 5, "bottom": 5, "zIndex": 5, "relativeTo": "map", "width": 480 } },
Robert, Thank you! I did not know that I need to look got the widget pool. Do you know any online trainings where I can learn how to do widgets customization? Thank you again!
Could you please specify what exactly I need to add? I am not good in programming.. Thanks!
You can open the main config.json of your app and add a width property to that specific widget so that the label shows in full.
