Is there anything wrong with loading data into versioned feature class using the data load function in ArcCatalog?I performed this task on a Street_Centerlines feature class in my own version, but it appears to have caused a massive data corruption to occur in both my version and the Default version. I hadn't posted the changes, but I did perform the data load outside of an edit session. I tested this process in an inactive sde database, and it worked flawlessly. When I later attempted it on the active database (which has considerably more overhead), it broke.The goal here was to delete all features from the Street_Centerlines feature class, and load in an updated version of the feature class without disconnecting users. I know this isn't the best practice, but I was trying to work around the limitations of using Truncate and Append on a versioned data set. Any thoughts or insights on this topic are appreciated!
