hello my problem is that this tool works perfectly in IDLE or PyScripter programs, but if I use in the script in ArcGIS desktop this problem occurs: arcgisscripting.ExecuteError:ERROR 000582...why not executing in Arcgis script and the other progran yes?the tool SelectLayerByAttribute management is inside the arcpy.da.UpdateCursorthis is my code:import arcpy import datetime arcpy.env.overwriteOutput = True territory= arcpy.GetParameterAsText(0) path= arcpy.GetParameterAsText(1) territory_lyr= path+ "territorios_lyr" arcpy.MakeFeatureLayer_management(territory,territory_lyr) fields= ("FID", "avg_mindis", "I_conc", "Max_lenght","TamanoTerr") with arcpy.da.UpdateCursor(territory, fields) as cursor: for row in cursor: currentID= row[0] where= "FID="+str(currentID) arcpy.SelectLayerByAttribute_management(territory_lyr, "NEW_SELECTION",where)
