protected function Map_mapClickHandler(event:MapMouseEvent):void { //allow user to enter size of square desired in map units if(tInput1.text == ""){ Alert.show("Please enter a number in the text input before clicking the map."); }else{ var size:int = Number(tInput1.text); var halfSize:Number = size/2; var center:MapPoint=Map.toMapFromStage(event.stageX, event.stageY); var extent:Extent = new Extent(center.x - halfSize, center.y - halfSize, center.x + halfSize, center.y + halfSize, map.spatialReference); var newGraphic:Graphic = new Graphic; newGraphic.geometry=extent; newGraphic.symbol=symbol1; gLayer.add(newGraphic); } }
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" xmlns:mx="library://ns.adobe.com/flex/mx"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Polygon; import com.esri.ags.geometry.Polyline; import mx.controls.Alert; protected function Map_mapClickHandler(event:MapMouseEvent):void { //allow user to enter size of square desired in map units if(tInput1.text == ""){ Alert.show("Please enter a number in the text input before clicking the map."); }else{ var size:int = Number(tInput1.text); var halfSize:Number = size/2; var center:MapPoint=Map.toMapFromStage(event.stageX, event.stageY); var botLeft:MapPoint = new MapPoint; //new mapPoint is assigned the same coor sys as the map botLeft.spatialReference=Map.spatialReference; //units defined by the spatial reference botLeft.x=center.x-halfSize; botLeft.y=center.y-halfSize; var botRight:MapPoint = new MapPoint; botRight.spatialReference=Map.spatialReference; botRight.x=center.x+halfSize; botRight.y=center.y-halfSize; var topRight:MapPoint = new MapPoint; topRight.spatialReference=Map.spatialReference; topRight.x=center.x+halfSize; topRight.y=center.y+halfSize; var topLeft:MapPoint = new MapPoint; topLeft.spatialReference=Map.spatialReference; topLeft.x=center.x-halfSize; topLeft.y=center.y+halfSize; var newPolygon:Polygon = new Polygon; newPolygon.spatialReference=Map.spatialReference; newPolygon.rings=[[botLeft, botRight, topRight, topLeft, botLeft]]; var newGraphic:Graphic = new Graphic; newGraphic.geometry=newPolygon; newGraphic.symbol=symbol1; gLayer.add(newGraphic); } } protected function clearGraphics_clickHandler(event:MouseEvent):void { gLayer.clear(); } ]]> </fx:Script> <fx:Declarations> <esri:SimpleFillSymbol id="symbol1" style="solid" color="0xFF0000" alpha="0.3"> <esri:outline> <esri:SimpleLineSymbol style="solid" color="0x000000" width="1" /> </esri:outline> </esri:SimpleFillSymbol> </fx:Declarations> <s:layout> <s:VerticalLayout gap="10" horizontalAlign="center" paddingBottom="20" paddingLeft="20" paddingRight="20" paddingTop="20"/> </s:layout> <s:BorderContainer id="mainBC" width="100%" height="100%" borderVisible="true" borderAlpha="1" borderColor="#FF0000" borderStyle="solid" borderWeight="3"> <s:layout> <s:VerticalLayout horizontalAlign="center" verticalAlign="middle" paddingTop="5"/> </s:layout> <esri:Map id="Map" logoVisible="false" mapClick="Map_mapClickHandler(event)"> <esri:ArcGISDynamicMapServiceLayer id="mapSvc" url="yourMapServiceURLHere"/> <esri:GraphicsLayer id="gLayer"/> </esri:Map> </s:BorderContainer> <s:TextInput id="tInput1" text="5000"/> <s:Button id="clearGraphics" label="Clear Graphics" click="clearGraphics_clickHandler(event)"/> </s:Application>
