Hallo, <\/P>
Ik heb geprobeerd dit voorbeeld te reproduceren http:\/\/carto.maps.arcgis.com\/apps\/MinimalGallery\/index.html?appid=b3d1fe0e8814480993ff5ad8d0c62c32#viewer=dce81739717342026;<\/A> <\/P>Ik kan niet vinden hoe ik de kleuren van de proportionele symbolen kan veranderen op basis van een stringvariabele zoals de politieke partij... Wanneer ik ga naar "vary symbology by attribute - by color", worden alleen numerieke variabelen voorgesteld.<\/P>Dank u voor uw hulp!<\/P>Me9l<\/P><\/BODY><\/HTML>
https://community.esri.com/message/928111-re-how-to-symbolize-by-type-and-size-in-pro?
Hello Melanie,
Unfortunately I can't see the map you are referencing, but I think I know what you are looking for.
The trick is to apply the color before the size.
For Primary Symbology, choose Unique Values.
For Field 1, choose the string field (for example political party).
At the top of the Symbology pane, click the green Vary symbology by attribute button.
Expand the Size section.
For Field, choose a numeric field (for example number of votes)
Check the Enable size range box.
Adjust the Minimum and Maximum sizes to suit your map.
