We currently don't have a composite symbol in the API. If I can gather requirements then this can be considered for a future release.
The sample application shows you how you can create a composite symbol made up from a few different things.
Does this answer your question?
/** * Sets the direction of travel property on this symbol * * @param angle The direction of travel to set. * @param angularUnit The units for the direction of travel. */ public void setDirectionOfTravel(double angle, AngularUnit angularUnit) { this.symbols.remove(this.directionOfTravel); this.symbols.remove(this.directionOfTravelGroundLine); double radians = swapCompassHeadingAndTrigAngle(Code.RADIAN == angularUnit.getID() ? angle : angularUnit.convertToRadians(angle)); boolean isGround = 'G' == this.sic.charAt(2) || 'g' == this.sic.charAt(2); if (isGround) { //Battle dimension is Ground; draw line straight down behind frame BufferedImage groundImage = new BufferedImage(DIRECTION_LINE_THICKNESS, DIRECTION_OF_MOVEMENT_LENGTH, BufferedImage.TYPE_INT_RGB); Graphics2D g = groundImage.createGraphics(); g.setBackground(Color.BLACK); this.directionOfTravelGroundLine = new PictureMarkerSymbol(groundImage); this.directionOfTravelGroundLine.setOffsetY(DIRECTION_OF_MOVEMENT_LENGTH / -2); this.symbols.add(0, this.directionOfTravelGroundLine); this.updateSymbol(); } //Draw arrow directly from center and on top of frame double x = DIRECTION_OF_MOVEMENT_LENGTH * Math.cos(radians); double y = DIRECTION_OF_MOVEMENT_LENGTH * Math.sin(radians); BufferedImage directionImage = new BufferedImage(2 * DIRECTION_OF_MOVEMENT_LENGTH, 2 * DIRECTION_OF_MOVEMENT_LENGTH, BufferedImage.TYPE_INT_ARGB); Graphics2D g = directionImage.createGraphics(); g.setColor(Color.BLACK); g.setStroke(new BasicStroke(DIRECTION_LINE_THICKNESS)); g.drawLine(DIRECTION_OF_MOVEMENT_LENGTH, DIRECTION_OF_MOVEMENT_LENGTH, DIRECTION_OF_MOVEMENT_LENGTH + (int) Math.round(x), DIRECTION_OF_MOVEMENT_LENGTH - (int) Math.round(y)); double firstArrowAngle = radians + Math.PI + DIRECTION_ARROWHEAD_ANGLE; double firstArrowX = DIRECTION_ARROWHEAD_HEIGHT * Math.cos(firstArrowAngle); double firstArrowY = DIRECTION_ARROWHEAD_HEIGHT * Math.sin(firstArrowAngle); double secondArrowAngle = radians + Math.PI - DIRECTION_ARROWHEAD_ANGLE; double secondArrowX = DIRECTION_ARROWHEAD_HEIGHT * Math.cos(secondArrowAngle); double secondArrowY = DIRECTION_ARROWHEAD_HEIGHT * Math.sin(secondArrowAngle); g.fillPolygon(new int[] { DIRECTION_OF_MOVEMENT_LENGTH + (int) Math.round(x), DIRECTION_OF_MOVEMENT_LENGTH + (int) Math.round(x) + (int) Math.round(firstArrowX), DIRECTION_OF_MOVEMENT_LENGTH + (int) Math.round(x) + (int) Math.round(secondArrowX)}, new int[] { DIRECTION_OF_MOVEMENT_LENGTH - (int) Math.round(y), DIRECTION_OF_MOVEMENT_LENGTH - (int) Math.round(y) - (int) Math.round(firstArrowY), DIRECTION_OF_MOVEMENT_LENGTH - (int) Math.round(y) - (int) Math.round(secondArrowY)}, 3); this.directionOfTravel = new PictureMarkerSymbol(directionImage); if (isGround) { this.directionOfTravel.setOffsetY(-1 * DIRECTION_OF_MOVEMENT_LENGTH); } this.symbols.add(this.directionOfTravel); this.updateSymbol(); }
