Joseph, That is correct... But there is a possible work around... You can add the feature type layer and set its alpha to 0 and exclude it from the TOC and add the map service as type dynamic with a alpha of 1 and that would be the one that shows in the map and in the TOC (grouped), but the feature type one will not show in either but it will work for the AttRelateInfoWinWidget.
If you add a layer to Flex Viewer and specify the type as "feature" than grouping is not possible...
If you have layers grouped in the MXD, and add the layer to the viewer as type "dynamic" than the grouping will be maintained.
