I have a project with multiple layers from my database loaded in to it. However, I have one layer that won't load into the map. It's just a simple line layer. It gives me the error message:: "Failed to add data, unsupported data type."
Any ideas?
Thank you Dan. I just searched and found this question. Yes, I will post my question again in the Pro SDK.
ArcGIS Pro SDK might be a better place to post your query... this thread is quite old
I have same error in Pro. I was trying to add a layer from my file geodatabase using Pro SDK. Keep getting "Failed to add data, unsupported data type". I can manually add it to Pro without any issues. Any ideas?
Here are my codes:
await QueuedTask.Run(()=> { Uri uri = new Uri(sPrjDB + "\\Map\\Map.gdb\\Pipe"); LayerFactory.Instance.CreateLayer(uri, MapView.Active.Map); });
Lyle
I am sure you have figured this problem out by now but I just ran into this same issue myself. I could see all of the layers in my database but when I tried to add it into my map I would get an error. I did some poking around and figure out that it was a permission issue. Once I connected to my database using the correct account. I was able to add my layer into the map.
It is one of our most common and most used layers in our enterprise geodatabase. I have layers from this same geodatabase that work just fine but this one won't work. It opens fine in ArcMap. I could do a work-around but I'm really trying to get to the bottom of why it won't show.
what is the file type? is it in a geodatabase or a separate file? can you open it in arcmap? if so, export it out in another format in another location and see if that can be loaded
