My installation of Arc 10.4 has suddenly stopped opening ecw files. It did this after I simply closed the programs (ArcMAP and Arc Catalog) and later reopened them. We need to use ECWs so a fix would be hugely appreciated!
Thanks for that. I tried renaming the "raster" registry key to "OldRaster" without success, as the functionality has returned with the installation of the ECW plug-in I'll hold off on the updating of the app. profile for now but very grateful for the suggestion.
Try Resetting your ArcGIS application profile.
Also make following changes to registry
*Note: The templates of ArcGIS Desktop (ArcMap/ArcCatalog/ArcScene) will be set to default.
Reboot machine and start ArcMap.
Not sure if this is the full explanation: I installed the ECW for ArcGIS Desktop plug-in and ECW functionality has returned to ArcMAP and ArcCatalog. However, the plug-in was not previously installed so Arc10.4 must have native ECW support which has somehow become corrupted during my closing of the programs. Hope this helps someone else.
Thanks, yes, it was very odd. I used the Windows cross icon (top right corner of window) to close them as I was in a hurry as opposed to the file...exit command, that was the only unusual part of the process. Nothing was installed in between to the best of my knowledge.
If that is all you did, I would contact tech support since ecw is a supported format. You might want to think back to see if anything was updated or installed in the intervening period
