Domme vraag... Ik zou graag de ArcGIS Pro GUI willen gebruiken om rasterpixels te selecteren en hun x,y-locatie en volledige waarden te zien. Mijn raster heeft waarden variërend van 10^-12 tot 10^-8, dus de pop-up attribuutinformatie toont mij alleen 0.000000. Ik veronderstel dat als ik de x,y-locatie kan krijgen, ik python GetCellValue kan gebruiken om de werkelijke waarden te zien.<\/P>
<\/P>
Enkele aanvullende opmerkingen die relevant kunnen zijn:<\/P>
Alvast bedankt voor alle hulp!<\/P><\/BODY><\/HTML>
i have the same problem. when I click with the Explore on a raster I get the pixel value but not the coordinates of the point where I clicked on the raster (I can’t see the coordinates that you marked in red above).
Hi Andrew,
You can locate x,y location at the bottom of the above window, as shown in the below screen capture
Hi Simon: Thanks for the suggestion. The Explore tool is not quite behaving as you describe. I poked around a bit but don't see a setting to tweak, so I apologize if I'm missing something. Currently, the pop-up does not show x,y location, but does show the cell value (however, it's still as 0.000000, though the value is something < 10^-6).
The Explore tool, on the map tab, works like the identify tool, when you click on the map. This will pop up a window that shows the pixel value and the location you clicked.
The Raster Item Explorer is only for mosaic datasets. If you have a mosaic dataset, the icon will appear on the Image Server layer tab.
Let us know if these answer your questions.
Simon W
