Want the user to click a link that brings them to collector, opens a particular map, and only turns on particular layers in that map based on conditions in the URL.
Can such aa workflow be accomplished?
No, there isn't. Please see my comment above:
>> At this time, the URL you can use to launch Collector honors the layer visibility as it was authored with the map. You can see the parameters that Collector honors when opening maps from a URL here: Deploy your map—Collector for ArcGIS | ArcGIS
Is there a way to pass in a layer ID to turn on that particular layer? Or the ability to add particular layer to a map?
If this is a workflow that your users need, please post in an Idea about it, and include details of how you would make use of this functionality.
ArcGIS Ideas
Hi Joe - At this time, the URL you can use to launch Collector honors the layer visibility as it was authored with the map. You can see the parameters that Collector honors when opening maps from a URL here: Deploy your map—Collector for ArcGIS | ArcGIS
