just wondering if I am missing anything behind the scenes?
import arcpy import os import shutil source_dir = r"source\dir" arcpy.env.workspace = source_dir table = r"selection_table" outDirBase = r"output\folder" if not os.path.exists(outDirBase): os.mkdir(outDirBase) def GetList(table): name_list = [] s_curs = arcpy.SearchCursor(table) for row in s_curs: name = row.Name name_final = "xyz_"+name.split("_")[1] name_list.append(name_final) return name_list nts_list = GetList(table) dir_list = [("bare_earth_DEM_ascii","be"), ("bare_earth_hillshade_tif","be"), ("full_feature_DSM_ascii","ff"), ("full_feature_hillshade_tif","ff"), ("intensity_image_tif","ii")] # Get directory name and associated file prefix from tuple list for directory,pref in dir_list: # Create a variable to hold the full path to the export directory new_dir = os.path.join(outDirBase,directory) # If this folder doesn't exist, create it if not os.path.exists(new_dir): os.mkdir(new_dir) # Create a variable to hold the full path to the source directory in_dir = os.path.join(source_dir,directory) # Loop through grid locations in the list of selected grids for nts in nts_list: # Assign the associated prefix to the current grid in the list var_in = pref+nts[2:] # Create a list of files in the source directory to test against file_list = os.listdir(in_dir) # Loop through all files in the source directory for filename in file_list: # If the current file matches the if filename.startswith(var_in): print "copying {0}".format(filename) shutil.copy2(os.path.join(in_dir,filename),os.path.join(new_dir,filename))
