We use ArcGIS Online to host maps that we don't want to be publicly accessible. Map services are provided by our instance of ArcGIS Server. We have both ArcGIS Online and ArcGIS Server. ArcGIS Online allows you to setup groups to control access to your maps. If I understand correctly, you don't need a subscription for maps that are publicly available. Also, you probably lose the ability to use map groups to categorize your maps (that is, without a subscription).You can get away without purchasing an ArcGIS Online subscription. Use the ArcGIS mobile content section on your ArcGIS Server instance to host your maps. You have to go through a bit of a tedious process to get the JSON document built that becomes your actual map. You can get through the process though. Security is not taken care of as it is with an ArcGIS Online subscription. You'd pretty much have to setup your own security. It can be done, but an elegant solution will require a fair amount of time.You will likely find that ArcGIS Online has quite a few bugs. It's mostly usable.Paul Lohr
I've been asked why do we need a subscription for ArcGis Online when we have an ArcGis Server with an Enterprise license. What are the advantages of ArcGis Online over an ArcGis Server, if any? I need a business reason to justify the expense of the subscription.A few months back I attended an ArcGis Online demo and I asked why you still needed an ArcGis server if you have an ArcGis Online subscription. And the answer was ArcGis Online didn't yet offer all the features that a server provides. Is there a matrix that details the differences in the features between the two.I work as a sys admin who manages the ArcGis Server. I'm not a Gis Desktop Analyst with an in depth knowledge of the product gained from working with it eight hours a day.Thanks
